1 - 20 of 23 Posts
2010-2012 Range Rover Sport
Are there any diagrams or pictures available that show the installation of the wiring associated with a trailer hitch on a 2012 Range Rover Sport. It looks like the part # ( VPLST0072 ) is specific to model years 2012-2013. From the online pictures there appears to be only two connectors on the harness? Does anyone know where these connections can be found?[h=2][/h]
2013-2015 Range Rover Sport
Following. I just ordered the wiring harness and towing hitch for my 2013 RRS.
From what I read , you need to remove the tail light on the driver side and also the carpeted panel in the trunk on the driver side and you should be seeing some "unused" plugs.
Also, you may have to remove the bumper cover to route the wiring harness.
FYI According to the manual If you have the surround camera system there's a Tow Assist mode for trailer guidance. It uses a camera and needs a one-time setup and a special sticker on the trailer positioned according to specific instructions available from the dealer.
Not trying to hijack the thread, but when you are not using the two hitch, where do you store it?
Discussion Starter · #6 ·
From what I can tell the wiring harness for the 2012 & 2013 is different from previous L320’s in that it is one piece with two connectors that connect between the bumper and the bumper frame. For these models it looks like there is no interior panel removal. The Utube videos online are for the 2005 thru 2011 models.
Discussion Starter · #8 ·
Discussion Starter · #9 ·
That doesn’t explain how the wiring harness is installed on a vehicle that is not originally equipped with one.
Thank you!! Do you have a picture that you can share please? I tried all the open slots and the hitch didn't fit in any. TIA
The hitch goes in the styrofoam storage area under the rear compartment flap with all the Jack parts
Discussion Starter · #11 ·
I haven’t purchased a hitch yet, I’m still trying to figure out how to install the wiring harness. But I do know there are two different quick release hitches that work on the Range Rovers, one is bigger ( longer ) than the other.
I had received the wiring harness from Atlantic british today. Wiring has 2 plugs. Came with instructions(not detailed).. Looks like all that needs to be done is remove the bumper cover and install the wiring harness and obviously coding after
Just completed the installation.
I had removed the tail lights first. Passenger side is optional, but you will have to remove the driver side if your truck has pdc.
Then remove the bumper cover and you will see the plugs on the driver side reinforcement bar. The wiring harness comes with instructions and once you remove the cover, it will be obvious. Took me about an hour to do this.
I did this back in 2015 on my 2010. It sounds like a similar procedure. I got as far as I could on my own (remove taillight, etc.) but I didn't trust myself to get the bumper cover off. I had a certified LR local place do it for me for less than an hour of time.
Also worth doing if you plan to tow any weight is to get a brake controller. That was really easy to connect. There's a blank connector behind the steering column. Simply remove the interior panel below the steering wheel and you should find it back there ziptied to the back. I think it required the Ford adaptor for the Brake Controller. I towed a travel trailer with brakes on it and the controller and Rover tow system was incredible. happy towing.
Where does the harness plug connect to? Im doing the same installation on a 2012 RRS and cannot find where the harness plugs in to?? please advise. thanks
1 - 20 of 23 Posts
