1 - 1 of 1 Posts
cross posted in DSOURCE but maybe will get more RRC specific help here. 1994 RRC, key goes into ignition and turns fine, but doesn't stay in the position II very well. So when you start it, it wants to turn back off into the first position and therefore turns off. You have to start it and sort of hold it for a second to get it to stay. Anyone ever had this issue?
Someone suggested instead of the ignition itself (which cant be bough tnew), maybe I need part# STC932, which is the actual switch and what should contain the detent springs to hold the key in each position.
Thoughts? I am also fine rigging it such that it starts with a blank key.
1 - 1 of 1 Posts
