1 - 1 of 1 Posts
So after checking for all the usual splits in the boost hoses I finally found the problem a crack in the right-hand inlet manifold if anybody else is having this problem pressurize your inlet hoses from the intercooler and squirt some soapy water over the top of the heads to check for any leaks... just for now I have done a temporary repair using epoxy I tried the expensive stuff which failed after 2 days I have now found a cheap product from Poundland that has so far lasted for three weeks even with the caravan on
1 - 1 of 1 Posts
