1 - 20 of 24 Posts
Hey Everyone,
After purchasing my 2011 SC with 105K miles on it the first items on my check list are transmission service, transfer case and differential fluid replacement.
A transmission, differential and transfer case "kit" from Atlantic British is $550 after taxes.
https://www.roverparts.com/Parts/ATFCKOMEWFL
https://www.roverparts.com/Parts/DTCM400A
However, when I called a local independent LR shop to inquire about labor costs, he offered full "4 wheel drive service" (transmission, transfer case, differentials and supposedly flushing the torque converter as well) using genuine land rover parts for $595.
Am I missing something here? I'm either overpaying for those kits or the indy shop is giving me a great deal here. Thanks in advance
Michel
2008 Range Rover L322 HSE
I've used Atlantic British a couple of times, but in my cases found that items they at very least suggest that they're Land Rover brand parts aren't. It tricky with them - I really have to look closely for any clue of a brand with their descriptions.
And I've never considered them to have the best prices for anything I've ever needed.
I did like British Pacific, which was bought by or merged with Atlantic British. But I haven't had good experiences with Atlantic British myself.
I like Rock Auto, because I always know what brands they have. Unfortunately they don't carry genuine LR parts, although they do sell the original manufacturers such as Behr Hella, Wix, and others that are made for and stamped LR.
But when it comes to transmission filters, I've used British Parts of Utah, or Merriam Jaguar Land Rover for genuine LR parts.
But that said, Atlantic British does put together packages. But the "OE" packages aren't genuine LR, but it's good that they include the ZF Lifeguard.
But on the other hand, I'd rather have the steel pan & separate filter than the filter/plastic pan.
$595 is a great price for all the items quoted. I don't know how they do it for this very little, my only guess is they have specialized machines that do the flushing in much shorter span of time than when done by hand. Even then I am still not sure how the price is this low. Just for laughs, I called my local LR dealer and got a $1,300 quote for a transmission flush alone.
Agreed, I buy from Atlantic British as a last resort. That said, I did buy their transmission fluid and filter upgrade kit from them for my 2006 HSE. Using LR replacement filter and pan would require much more labor, as you have to remove the tranny cross member to drop the pan and filter.
2011 Range Rover Supercharged
Hey Everyone,
Michel
Michel,
The $595 price is suspect to me. I cannot imagine they will be using genuine ZF Lifeguard 6 fluid or genuine T-Case/ Electronic locking diff fluids. Parts/Fluids alone are $450-$500 at wholesale pricing. I would only ever use the genuine Lifeguard fluid in the trans and I would also only use the genuine LR electronic locking diff fluid. So if you can 100% confirm this place will use those genuine fluids, It seems like a no-brainer to pay the $595. But it does seem a bit "too-good-to-be-true".
Also note that you do NOT need the 2-part pan/separate filter for the Full Size L322 Rovers. The trans pans on these Fullsize RR's will allow the whole pan assembly to drop straight down. So you can save a few bucks and get the integral pan/filter assembly (Genuine LR). Also note that your S/C Rover will have the rear electronic locking differential. It does require special fluid that differs from the non-electronic diffs. Atlantic British sells kits for both types. You linked to the non-electronic kit.
Lastly, If you are somewhat mechanically inclined, I would perform these fluid changes yourself. If you have the capability/jacks/jackstands to safely lift the Range Rover off the ground an all four corners to slide underneath, the rest of the work is pretty trivial. The trans pan drops straight down after removing the 20+ torx bolts (all of which have easy access). There is also easy access to both the drain and fill plugs on the transmission. You should also replace the mechatronics seal on the Transmission while you have the pan off. It is prone to leaks and pretty simple to replace... but likely to be the most "fiddly" part of the entire job.
The Transfer case and Diff fluid are also both simple jobs, again, with easy drain/fill plug access. Just make sure you order the correct fluids (and quantities) and also order replacement drain and fill plugs for the Diff's and T-Case.
Also, if you want to splurge on a new tool for the job... Consider this: https://www.ecstuning.com/b-schwaben-parts/3-liter-multi-functional-filler-system/007311sch01a/
I have this unit, and it makes filling fluids very easy. It includes a bunch of different adapters for filling various Diff's, TC's and Transmissions. It even doubles a pressure Brake bleeder as well.
BillConn,
If you watch the Atlantic British video on replacing the one piece factory LR transmission pan & filter, it seems obvious that you cannot do so without moving/removing the tranny cross member or cutting the stem of the filter.
The RAVE service manual also states that you cannot simply drop the tranny pan.
If you know of a method that circumvents this, I and I"m sure a few others would be very interested.
BillConn,
RR Sports and LR4's have access issues that make the 2-part pan/filter very advantageous. Full Size Range Rovers w/ the ZF 6HP28 transmission don't have the same cross-member interference.
Have a physical look under your 2006 HSE and you will see for yourself. Also I am not sure what service manual you are looking at. For sure the 2010-2012 service manual doesn't indicate any "extra" steps beyond removing a small cover plate and removing the 21 bolts. This is direct contrast to the LR4 service manual, for example, where you must loosen some exhaust manifold bits, drop the trans x-member, etc etc.
...The RAVE service manual also states that you cannot simply drop the tranny pan...
I wish RAVE would apply to the 2011 -2012 MYs, but it doesn't.
As I understand the only option for the 2011 - 2012 is TOPIx.
Do you have the PDF for the 2010 Range Rover? PM me if not, I can get you a digital copy
Based on my research the pan does not just drop in 2011. I think it requires the filter stem to be sewn off. I also do not believe I have rear locking diff
Motorsport has an excellent writeup on transmission flush, just not the filter change here:
https://www.rangerovers.net/forum/6 I just looked under my 2012, and it looks like the pan is clear of the tubular frame for the transmission/transfer case. There is something of a skid bracket under the pan that looks like it it just comes of with a few bolts, maybe the trans pan bolts.
https://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/127114-diy-complete-transmission-fluid-flush.html
Not sure where the misinformation comes from. The 2006-2012 L322 allows for complete transmission pan removal without any major disassembly. There is a heat-shield and it’s support bracket that must be removed first... but other than that, you are good to go.
as for the “flush” procedure highlighted in the link... I am not sure I’d go through the extra hassle unless your fluid looks really bad and previous fluid/filter changes have been neglected. It also bypasses any filter replacement which is also important. I have done this type of trans flush before on other cars via the trans cooler as mentioned in your link. I prefer to start and stop the engine ever 1-2Qt of fluids as opposed to trying to fill rapidly whilst the fluid continues to pump out. Seems more controlled than trying keep up with the trans pump.
But as I said. I wouldn’t bother trying to flush the converter. A drain, filter swap and proper refill should be more adequate for routine maintenance.
Lastly, regarding the e-lock Diff. Check your VIN on Topix or the window sticker if you have it. I was under the impression it was a standard feature on the S/C models for 2010-2012. I’ll have check my Window Sticker to see if it was a standard item, or an additional $$ option on my RR.
Discussion Starter #15
Bill, thank you for the additional feedback. This definitely makes the DIY sound easier. I might just attempt this on my own.
The transmission was never serviced by the previous owner, so a full flush and filter change might be more beneficial at 100K.
As for the differential, it was standard on the early 2010 models, then it became an option. Mine shows "REAR AXLE OPEN DIFF" in Topix
Interesting. On my window sticker it reads “No Charge Locking Rear Diff”. So maybe you had to order it, but it was at no additional cost. *shrug*
I also got Mark and your requests for the service manual, so I’ll get those sent ASAP.
Locking rear diff comes with the supercharger.
2007 HSE
I believe if you put it in "Snow" mode, you should see the lock icon on the infotainment screen.
Regarding the transmission fluid, the indy mechanic could be using Mercon SP instead of ZF Lifeguard 6 fluid. Use at your own risk, but all indications are that it is the same fluid.
I've done the transmission fluid a couple of times, and now have the steel pan (it was just slightly more than the plastic pan). You should know almost immediately if the fluid change was done correctly -- your shifts will be very smooth. I had a questionable change once, took it back, and they corrected it. I use the local Ford dealer for pretty much all service.
Also, watch for leaks the next day (puddles or drips the next day). When the steel pan was installed on mine, the drain plug seal was leaking. They fixed by using teflon tape around the threads and no problems since.
Also, I've found Miami British to have some pretty competitive pricing.
Here's the option portion of the window sticker from my 2011 Range Rover SC:
Notice: Electronic Rear Diff Lock $500.
Your indy shop sounds like a screamin' deal. Check their parts list for what you'd be getting.
Good luck!
Good luck!
Interesting that my 2011 had it as a no-charge option. I am also jealous of your Adaptive Cruise Control. That was the ONLY thing I had to concede on when I purchased our RR S/C
1 - 20 of 24 Posts
