21 - 37 of 37 Posts
My 2016 had the same issue, at first they thought it was a software update also. They leak tested the system and eventually found it was a bad nox sensor. Took them nearly a month, got to know an evoque really well.
I received a number of software updates and have not had an issue since although it has been less than a week since I got it back. The SA wasn’t there when I picked it up so I didn’t get an explanation and am only going based on the service paperwork.
Def quality warning light 515 miles before engine disabled, recently re filled with other brand of addblue was told initially by dealer that because i had not used landrover brand the mend would be chargable, after 1 hour of tinkering my range rover v8 vogue was repaired after a software update with no charge.
I'm glad they didn't charge you, but don't ever accept that from a dealer - the DEF you get in any auto parts store for $12 per 2.5 gallons is exactly the same as the stuff they pour in for twice that cost. Theirs isn't "special."
AdBlue does need to be stored within a certain temperature range, and if you live in a very hot or humid area, buy the DEF you intend to use right before you use it, and use all the DEF in a container at once or throw any leftovers away. It does age out and can suffer from things like water "contamination" (extra water seeping in) or evaporation, which changes the percentage of urea in the solution.
2016-2018 Range Rover Sport
That's BS as others have said.
Urea is like engine oil in that it needs to be within specs. Not sure if it is SAE certified type of stuff though. 32-1/2% Urea and 67-1/2% water. That is like saying you need to use LR brand washer fluid.
The storage issue is pretty forgiving. When frozen and thaws it will not loose its spec. When it gets to hot for way to long than it goes bad but it very hard for it to loose its effectiveness/spec. When the US market starting working on using DEF I was at a conference specifically for DEF storage, dispensing, selling, etc. One of the tests that was talked about was when it was stored in an Arizona warehouse at 120 degrees for I believe a month. The DEF did not loose it isn't spec.
Hate it when dealers tell a customer what they think they need to know.
I knew of a dealer that talked a customer out of buying a new Hummer H1 and instead sold them a new H2. The dealer had both sitting on the lot and the BIG (LOL) selling point that the salesperson used was that the H2 got better gas mileage. LOL I guess the salesperson didn't want to sell a truck that cost $30,000 more.
Hello, has anyone had this error corrected and not reappear after about 3 months? I’ve had this issue “fixed” 5 times within the past 17 months, and each time it would reappear after 2-3 months regardless of the amount miles put on it. I currently have the warning on for the 6th time and my receipt from the previous repair mentions that if it occurs again, my cats/catalyst or something need to be replaced. 2016 FFRR 2016 btw
Also, has anyone tried calling LR’s customer service rather than a dealership?
Thanks!
Hello, has anyone had this error corrected and not reappear after about 3 months? I’ve had this issue “fixed� 5 times within the past 17 months, and each time it would reappear after 2-3 months regardless of the amount miles put on it. I currently have the warning on for the 6th time and my receipt from the previous repair mentions that if it occurs again, my cats/catalyst or something need to be replaced. 2016 FFRR 2016 btw
Thanks!
I had the same issue and it was never resolved. LR bought back my vehicle under our states Lemon Law. They would not let me purchase another TD6.
It took a bit of research and persistence with LR to accomplish but it has worked out in the end.
Discussion Starter #27
As my reply from 2/2018 above states, after replacing two NOx sensors and the cats, the issue for me went away and has not returned.
2016-2018 Range Rover Evoque
So here's my experience from downunder :)
I've just started getting the "Incorrect Diesel Exhaust Fluid quality detected" message... Got 585km before it won't restart.
So I took it to the service agent, who, after talking to a Range Rover service agent next door said my DPF is full, won't regenerate, and said I need a new DPF unit, new DEF injectors, programming, and a oil change as oil dilution is 16%.
All for $6500... um, Aussie dollars.
Never have I had a DPF full message or any alerts that it needs a clean, which according to the manual should pop up. I can't help but think they mis-diagnosed and repair cost is a joke.
As well, when the message popped up, I had been driving highway speed for a while, so if the DPF had to autoclean it had ample opportunity.
They also said not to drive the car as it risks not starting at any time and the countdown is not correct.
So I drove off saying I'm getting another opinion :)
Interested to hear if anyone else has had something similar ? Seems its either a sensor or software thing.....
They also refused to reset the countdown.
I'll post up what happens and the fix.
BTW I have a Land Rover Range Rover Evoque TD4 150 SE Auto 4x4 MY16
Been an awesome car up until a few hrs ago... >.>
Ok, I have an update....
Had my DPF unit checked elsewhere and it was fine. Was only 36% full and working ok. I had a clean done and dropped it to 10%, just to make sure.
Then I went to land rover, and after a software update, problem gone. They even added more DEF fluid so it's full, at no charge.
I've driven for a week now, did a nice long trip, and all good :) Actually my fuel usage is better now, by about 10-15% !
So my original (ex) service place is either completely inept or doing a scam. I'll be nice and just assume inept.
Hello,
My car is a 2018 Velar R Dynamic
Last week I had the same issue moments before taking it to the dealer for regular maintenance. Next day they called me they had changed the diesel pump....
We just bought a 2016 HSE TD6, have had a couple of weeks and received this message “No engine restarts in 76 kms incorrect diesel exhaust fluid quality detected” my question is, how accurate is that 76 kms? We are 100 kms away from a Land Rover dealer.
I was having this issue a while back. I just got on freeway and drove it for about 40 miles and then it cleared itself. Since then its never came back. Before all this I had a code for a bad NOX sensor also.
Have had my Range Rover Sport HSE TD6 at the dealer 4 times now for the DEF Quality warning with XXX miles remaining before no restarts allowed... The only fix has always been reset the code by updating the software. This last visit we were told the DEF Injector may be faulty. When I got home I removed the injector, very easy to do with one Allan bolt holding injector in place with a clamp. The end, when three small injector holes are, had white crystals built up on it from the DEF. I cleaned this residue off and reinstalled. I’ve also ordered a new injector to replace it too just to be safe.
286594
286595
Very accurate, pulls from your odometer. Do not turn vehicle off once you get to zero or it won’t restart. Had to have mine towed to the dealer one time due to this code.
I have had my 2016 Range at the dealership 6 times for the same issue. I even had to pay $300 once because they said the warranty didn't cover this and once again did not fix the problem. Love the car but if it's not functional it's not worth it for me, about to start car shopping...
21 - 37 of 37 Posts
