I was able to remove the top bolt but this bottom one is absolutely frozen. I was able to get the nut off the end but the bolt is frozen to the strut.
Tried the following:
I'm at my wit's end. This was supposed to be a straightforward job but I'm getting extremely frustrated.
Thanks all for any tips/tricks.
- Penetrating fluid/PB Blaster over the course of days/weeks
- Breaker bar
- Hammering it out from the opposite end
- Heat from butane torch (I don't have a propane torch)
- Wedging a screwdriver and trying to hammer it in between the bolt flange and the air strut to try to separate them.
- I even tried changing the way I jacked the truck up, switching from the side jacking point to the front jacking point where both front wheels are off the ground, in case this was due to pressure/weight on the bolt.
