Aloha all,
I don't post here much anymore, however this is a really important development........
Recently, I was directed by KCR (Thank you!) to a bloke named Simon.....
He has come up with a nifty postage stamp sized board which, when inserted into the Bosch engine ECU will send the mobilisation
code needed for the fueling and ignition to function. There are 3 wires to solder on to the board and one pin lead to clip.
Install takes about 15 min start to finish. He needs to know the mobilisation code as it is pre programmed into the chip.
He can provide the chip preinstalled into an appropriate ECU which just needs to be swapped in. No soldering skills needed.
There is also a jumper to install at the Becm to disallow it having a say as to cranking, which it does indeed
disallow in an alarmed and immobilised state.
With this device installed, I proceeded to annoy the Becm by locking with the fob, and unlocking with the key in the door.
Normally, this will trigger the alarm and immobilisation mode will be activated needing either the EKA or a push of the button on a working fob.
To my utter delight, I found that the engine started just fine and there were no notices on the dash. All systems worked fine as well.
Of note, the dashboard alarm Led does continue to flash as if the alarm is going off. As I have unplugged the sounder,
this is the only indication I have that there is anything going on. I believe sounder can also be disabled in Becm with Nano....
I then locked the car with the key, and waited 2 minutes.....The Becm goes to sleep, so no unwanted battery drain.
I got 2 of these and will install in the Borrego tomorrow.
The peace of mind this will bring to me with regard to wife and friends using the trucks is priceless! No worries about the dreaded
"Engine immobilised, enter EKA or press fob" message to them when far from me and the Nano (Also, always seems to happen on a dark and stormy night)
I believe this little board could keep a good number of very nice P-38s out of the Knackers yards!
Especially considering the difficulty / expense involved in getting replacement fobs now.
This is a must have for anyone without a fob, and wanting some peace of mind!
Oh, yes, I do not work for or with Simon. Please contact him if you have questions. He is now registered on this forum, so should respond.....He is "PsiDOC"
I shall continue to report on performance as needed, but so far? FLAMING BRILLIANT!!!!!
Cheers, Simon!!
Tom
Cheers, Simon!!
Tom
