I've got a store bought one in the truck right now, and I just thought I'd give it a go rebuilding an OEM one.
So, I took it apart and wrote down all the part numbers for the bearings, brush holder, etc.
I was able to source most everything on the internet.
Bosch voltage regulator/brush holder 1-197-311-549. Couldn't find a genuine Bosch unit anywhere, but there is an aftermarket one available. $40
Slip Ring is a pretty standard piece on all Bosch alternators. Got mine from an outfit called American Engine Corporation. $8
The rear bearing is 6203LHA. $10
The last piece I need that is evading me is the rectifier. The part number stamped on mine is 1-127-328-009. A search for that part number gives me nothing. No cross-reference or anything. Closest I could find that looks exactly like it, but says its for a 140A unit is here
http://store.alternatorparts.com/ibr860-bosch-type-140-amp-internal-bridge-rectifier.aspx
Anybody ever tackled this or have any suggestions (besides "take it to an alternator shop")?
Your rectifier is likely good. If you brushes and ring were FFed up your not going to get juice. I only replaced bearings, brushes and the stator ring in my ALT. It is pumping out all the juice it was originally. A little over 14 volts.. That Bosch alternator is a beast..
alternator parts place online helped me out and we figured out that the rectifier part number stamped on the side of mine was actually a part number for a capacitor ON the rectifier. The actual part number for the unit is 1-127-319-700 or IBR700 from that store I referenced earlier.
