Other than selling the IIDTool to finance a set of softer tires, NorCal RR is correct.
You can adjust the height of the suspension with the tool but there is no control over suspension firmness as the factory did not provide that adjustment.
What tyre pressure are you running?
Maybe you are on the high side. You can try running down to the manufacturer recommended pressures in the owner’s manual.
I usually run a lot higher (50 psi) and still think the ride is plush.
Hi, thanks, I lowered the pressure to around 38psi. I read in the RRS fórum that using the EAS one member lowered the suspensión 10mm and improved the ride. I am not sure whythat would make suspension softer. Also, not sure if with the IIDT tool something can be made to improve the ride. Thanks
Depending on your tire size, my 255/55/19s say 36 up front, 42 in the rear. If I drop it a bit, the ride becomes a little softer. It does seem to make sense that dropping the height would soften the ride as well. Less air in the bags. Not sure if it would have an ill effect on the longevity of the bags over time though.
