1 - 1 of 1 Posts
Hi guys,
I recently bought a 1990 3.9 project car. The previous owner had replaced the ignition system with a crane cams cd ignition box and coil, which has failed. I have just pulled the old system and replaced it with a new distributor (old one was shot,) ignition switch, neutral safety switch, suppressor, and coil. Only to find myself in a no spark situation. I have the white wire from the amplifier and the suppressor running to the positive on the coil, and the black/white from the amplifier, and the solid white from the maf sensor loom connected to the negative. Am I missing anything, or does the coil receive power from the white wire coming from the amplifier module?
Thanks in advance.
1 - 1 of 1 Posts
