1990 RR, vehicle runs great most of the time. Some times i come to a stop at a light and the RPMs drop very low. If i try to give it gas and move from the stop it wants to chug and spit back through the intake. (what it sounds like anyways) If i stop the car, shut off the ignition and restart the vehicle then it will Idle and drive fine until the next stop light. I took out the Air Bypass it was pretty dirty and cleaned it. Timing is good, new plugs, cap and rotor appear fine. Would love some ideas. I am new to the RR world just bought this a month ago and i am looking forward to fixing it up. Thanks.
Hello
I have a very similar problem. Take a look in "Bad idle when cold on 1993 4.2ltr LSE" (viewtopic.php?f=4&t=36667) there is a list of the things I've changed, may give you some ideas. The snag is, I've stll go the problem!!!
Good luck
nkg
you guys shold check the springs on the distributor. if one broke you may have wierd intermittent problems. make sure the advance is working properly
Thanks, i pulled the Air bypass valve and cleaned it. It was pretty bad, and drove it today. Only did it a couple of times, but not as bad. I will check the distributor just for something else to do.
