Hi all
Can anybody help me identify the connectors on the AM/FM aerial amps XUO000010/XUO000040 please?
I've searched on here and googled my little heart out but I can't find the info I need.
I want to tap into the aerial cable between the amps and the header in the dash in order to fit a Kinetic Digitizer DAB module, without having to remove the dash :?, so I'm thinking there's no reason that it couldn't go straight after the AM/FM amp output.
If it's not possible to tap in somewhere in the boot can anybody suggest a place where the cable is easily(ish) accessible? I have no idea where the cable is routed.
Thanks in advance.
Discussion Starter #2
Update - I believe that the single white wire is either power or power sense. I'm still stuck for all the others.
There also appears to be a cable at the back of the XUO000010 unit, could that be the antenna feed to the header?
