It looks like my 1999 P38 4.0L has sadly come to the end of its economic life. I took the heads off to investigate water loss and sent them away for a 6 thou skim to clean up the area around the water ports, but it looks like my real problem is the block. The area between the water port and the top hat liner of cylinder #2 is badly corroded. I have tried polishing this area to reduce the corrosion but it seems too bad to ever give a decent seal and it will just leave the firing ring to create the seal on the liner. What really frustrates me is the cost of trying to keep a P38 on the road. This morning i went to buy a thermostat for the rebuild and the local dealer wanted 61 pounds for something that other manufacturers like Merc charge 25 pds for. If i look at replacement engines then the UK vendors want 3 thousand pounds or more for a new or remanufactured one. Comparing this to the current market value for the vehicle of about 3.5 to 4k pounds its just not worth the bother of trying to fix it. So i have some soul searching to do this weekend. I either scrap the car or bite the bullet and spend some more money in the feint hope of fixing the rig and having a car i can rely on. Its been a great car in the 2 yrs i have owned it, but parts are simply far too expensive to make this a financially viable car to own.
If anyone has experienced the same doubts of P38 ownership and decided to scrap or repair please shout now as the scales are currently leaning towards scrapping it.
Nigel
Nigel
