1 - 14 of 14 Posts
Just got a 09 RRS HSE Lux, Stornaway Grey with 20" Stormer wheels.
What's your opinion on changing the front grill to a supercharger version. Yes or no?
I know it's a matter of taste but, i would just like to see what you guys think.
Many thanks.
the supercharger grill from a 2009 rrs looks much better then from the "normal" version. on 2010 its contrary the grill from the "normal" version looks better the the grill from the SC i.m.o im already changed it by my SC - but when you change it dont forget the side vents too...
greets
greets
Thanks. Do you guys think that i have to change the side vents too? I kinda like the grayed out look on the side vents cause it matches with my body paint. But if you guys think that it will look funny if i didn't change it to the SC version, then i will go ahead and change that too.
Many thanks again.
I would do what you personally like. You're the one who's going to be seeing and driving it so as long as you like it, then I would say that's good.
I would say just get the SC grill first since that's what you wanted in the first place and then see how everything looks together. If you think it looks awkward without the side vents, then I would proceed from there.
Post some pics when you get it done.
I strongly recommend switching the standard grill out for the supercharged grill
for the '06 - '09 models.
And yes, you must switch the side vents to the s/c as well.
Discussion Starter · #6 ·
Thanks. The SC grill should fit perfectly on my HSE grill, right? No adjustments? Same number/position of clips?
Straight swap, identical grills. The one color I think the gray 2006-2009 HSE grill doesn't look half bad is the Stornoway or Bonatti gray, if you are going for the monochromatic look... But the silver S/C grill definitely livens up the front end on any color Sport.
I actually went the other way, my Stornoway TDV8 had the S/C grill as standard, I changed it for the standard grill from my TDV6(but with the black/silver logo), I like the "colour coded" look better
i believe i have an extra s/c grille in my garage somewhere -- its the original one that came with the RRS...
i ordered an extra one, removed the grey border, and had it chromed to match the chrome side view mirror caps
Now all you need is a supercharger, brembos, the seats, the rear badge, and the tailpipes :thumb:
:roll: :roll:
1 - 14 of 14 Posts
