2002-2005 Range Rover P38A
Drivers side LH Blower motor issue.
The Blower does work when strait 12v is applied to the main Red/Black leads on the Blower, not via the 4 prong connector, so Blower works.
When 12v is introduced to the 4 prong connector, Hot & Ground, no Blower.
Checked every fuse under passenger seat and under hood, all fuses okay.
The RH Blower operates normally.
The 4 prong connector has the 2 main 12v leads and 2 smaller wires which I presume are feedback voltage to an ECU.
This is where I'm stumped, any suggestions where to look next are joyfully welcomed. It's super hot here in the south!!
I just went through a similar scenario with mine two months ago. First the passenger blower, then the driver side. Both were stuck on one speed below Max. The issue could be the resistor/speed control unit on the blower assembly itself (the heat sink thing at the top of the unit). LR does not appear to sell this separately -so, three options. Buy a new OEM blower (if still available), or buy a good used blower. Third option is that it appears a resistor unit from a Citroen XM is identical to the one on our trucks. Try searching for part number 62928311 and you’ll see from the images. I wound up buying used blowers (took a few tries) as it seems the resistor packs are not readily available here in the states. Next resistor pack that fails I will attempt to order one of these to try. Folks have tried to rebuild them in the past from what I’ve gathered. I would have done the same but was unable to locate updated specs for the components on the circuit board. Good luck!
Forgot to post that meter voltage at the 4 prong connector only reads ~.040v from the main Hot & Ground. That is why I wondered if there is something else impeding me getting power at the 4 prong.
Just replaced the blower motor and nothing - only .04v at the 4 prong connector.
Any other ideas on where to look next?
Look on you tube for RSW Solutions blower motor.
Storey is a member here and takes apart the motor and shows how it works. It helped me understand the system. I’d check the nearest junkyard for another blower or two. If I’m a hurry eBay. If you have time order new ones from LR Direct.
I assume you checked RL 7 and RL 8? In the fuse box??? Relays can stick open or closed. I had a few do that.
Discussion Starter · #7 ·
You sir were correct, RL7 was smoked. Replaced and LH Blower is now functioning. Thanks for the second pair of eyes, sometimes that's all that needed.
Well good. But bad also. My 2002 started having some issues. Check the fuse box where RL 7 plugged it. Is it discolored or brown at all? Mine was showing age pretty good. I bought a brand new fuse box and relays from LR Direct and replaced it in one afternoon. Saved a lot of headaches down the road. Best $250 I’ve spent yet. FYI you might want to do the same.
