There is a humming and vibration noise coming from my 07 L322 HSE at a certain speed range (100-120) km/hr. the youtube link shows the case. Can anyone identify the noise source and the solution?
Covered numerous times. Loose windshield trim either due to warping or broken retaining clips. A few folks have report that the plastic cowling at the base of the windshield also pulls away then vibrates.
You took a video of what you described, we got it. It is not at all uncommon. The possibilities are noted above. Have you inspected your trims yet?
Defenitly sounds like the windshield trim.
Even a small portion loose will cause your problem.
If all checks out ok, try the roof rails. They could also cause the noise but I would put money on the windshield trim.
