One of my next jobs is to connect all the ht leads up to the relevant spark plugs.
This is probably a simple question so apologies in advance, but how do I knwo which lead goes to which plug? I've searched the RAVE manuals with no luck - I can hardly find a mention about them.
Is it as simple as the length of each lead will only reach the correct plug?
You don't say which system you have Bosch or GEMS - the coils are different.
The easiest way is to remove one lead at a time and replace it - can't go wrong that way.
I did this about a month ago and I changed one at a time and tied a knot in the old cable after I had matched it up to the corresponding new one (length) its slow but safe
On the GEMS coil pack the numbers are stamped on to the black bracket that bolts it on to the engine, but they are hard to see......well it is a Rover :roll:
Sid.
It's GEMs engine, I hadn't noticed the numbers on the coil pack so will examine further! It does seem a daft place to put the coil pack.
I didn't remove the plugs, the top end of the engine was in the back of the car when I bought it!
Top end of motor in the back of car...I wonder why.
Nothing wrong with coil pack on back end of engine, looking at it where else would you have put them.
I do these vehicles day in day out so Im used to them
FRONT
1 ---- 2
3 ---- 4
5 ---- 6
7 ---- 8
Coils
(stamped on bracket)
1 goes to 1, 2 goes to 2 etc
Good HT leads shouldnt read more than 8k ohms with meter set at 20 k ohm setting.
