1 - 9 of 9 Posts
In the past month have been bitten by this bug once set hard code fixed problem now back. Dealer has had the car over a week no solutions cannot get to repeat. They are putting 50 miles a day on it no joy. When it goes into this mode no power at all suggestions please
For us it happens once or twice a week
I have the same issue on a 2018 model.
Limited performance warning come on and only turning off the vehicle would clear it.
This may happen at random and is a safely issue.
Been to dealership 5 times and till happening.
Asked manufacturer to replace vehicle and they refused.
Put them on Lemon Law notice. They set up a final repair attempt which failed.
At this point they are still refusing to replace vehicle so I had no choice but to file for Lemon Law arbitration.
It is my opinion that they have no idea as to root cause of this issue.
I would strongly suggest that you contact JLRNA and open a case. We were having the same issue with our 2018 TD6...as well as a host of other issues...and they really went above and beyond to resolve the issues. Loved the TD6 but am much happier with the new SCV8.
Same issue on my '17 but almost always when cold...ignition on / off clears...
Similar on my 17 on cold start. Now I get coolant level low every cold start then it goes away.
Sent from my SM-N950U using Tapatalk
You notice there is almost enough of us for a class action already (6 pax)?
Another diesel- 2016 HSE 70,000 miles started this weekend, everything flashed no brakes, no power steering, no coolant, hood open etc. There was no power steering when i drove- I just had the diesel filter changed a month ago - in dealer now..
Anyone have newer information here or an identified root cause? Our 2018 HSE TD6 has gone into limp mode 3-4 times now, typically within 4-5 minutes after starting from a cold start. Dealer had it for a day and drove it around but were not able to reproduce the issue. It's rare, happening perhaps once every 2 months or so. Hoping someone else is further along than we are here.
1 - 9 of 9 Posts
