The Dynamic Response stability control system and Brembo brakes are standard on the SC model.
Are these features available as options on the HSE in the US?
yes they will be available later thisyear. By the time you order and receive yours, you should be able to get those.
My USA 2006 RR Sport HSE has the Dynamic Response stability control system. It was standard equipment.
The RR Sport brochure given to me by the local dealership in May describes a "Dynamic Response" package -- which includes the Dynamic Response suspension and Brembo brakes -- as standard equipment on the SC and as an option only on the HSE. Moreover, the HSE option has an asterisk that says "delayed availability" in the US.
Something called "Terrain Response" is standard on the HSE, but that has to do with traction, not suspension leveling around corners.
Neither in the RR literature nor anywhere on line have I seen Dynamic Response suspension described as standard equipment for the HSE.
For example, on the USA RR site, when you try to "build your own" HSE, the Dynamic Response package is not listed as an option:http://www.landroverusa.com/us/en/_maintools/Build Your Land Rover.htm
What actually gets delivered to the US dealership for sale, I don't yet know.
