I'm just starting to look for a 2007 L322. On the 4X4 screen if there's a unlocked padlock on the rear diff. Am I correct in the assumption it has a rear e-locker?
No, the lock symbol shows on all of them, just never shows locked on the open diffs.
Easiest way is to get under and check for a big motor on the driver's side upper section of the rear diff, or check the build sheet if it's at a LR dealership. All 07-09 SC L322s have a locking rear, but it was an option on the NA vehicles.
So how fast do they lock? If I put it in rock crawl and low range do I need to roll forward to get them to lock?
No. It is variable locking, just putting into a different program doesn't force it to be full locked.
The easiest way it to actually look at the differential.
