I tried to put it inside the oven at 200 degrees and for 5 minutes and did it repeatly like the guy in you tube but it didn't work. Any ideas?.:)
2010-2012 Range Rover Sport
I would put it in the oven for about 8 minutes. Make sure the metal clips are removed first - along with the other components.
Just to clarify this for a European, when you say 350, you mean Fahrenheit, so 175ish Centigrade?
Guy
That's what he means - but I didn't have to use anywhere near that level of heat to open the lenses. I would imagine that there is less room for error at that level. I used low 200's for 8 minutes IIRC...
