I have to remove the finisher on the rear end of the roof before painting the roof.
It is the black finisher all the way across the rear end of the roof (mounted on the rear end of the roof) above the upper tailgate.
I can not find in the manual how to remove it, and am afraid of breaking it.
Can anyone tell me how to remove it ?
That's the D pillar. Check out RAVE or better yet, search this forum. There are many photos with tips on how to do it right... and wrong .
N.
Are you are referring to the "spoiler" at the top of the upper tailgate that hides the wiper? My memory is a bit foggy but I think it's held on with two bolts, one on each side of the wiper spindle. You'll need to turn on the rear wiper and open the tailgate when the wiper arm is pointing down. THis will give you access to the right hand bolt.
Thank You very much for your fast answers.
I can not find it in the Rave manual.
It is not the D-pillar.
It is not the "spoiler" at the top of the upper tailgate that hides the wiper.
The finisher is a aprox 3 cm black list and 160 cm wide (as wide as the roofpanel) with a 4 mm rubber edge as sealing toward the painted surface of the roof, and mounted on the rear edge of the roofpanel between the 2 D-pillars abowe the rear tailgate.
