1 - 16 of 16 Posts
Help - I am trying to do something ridiculously simple. I bought this '95 classic and am trying to pull the head rests all the way off so I can slip over some seat covers. Both headrests are in the lowest position and I cannot get them to come up and out. Any tricks to this? I can get a little movement but the they won't move out of the detent. Thought about dribbling some WD40 down the steel rods.
Is it really just jerk up like hell?
Recline the seats, get in the back, and decapitate.
A little Kroil oil, a penetrating oil is an option.
I seem to remember a release button between the two rods at the top of the seat but that may be another vehicle.
Good luck.
THere are no latches, buttons etc. The detents match up with spring clips. The only reason to use oil would be severe rust inside your seat backs.
Thanks folks - I will proceed - Sounds like pulling the shifter knob off of a DiscoII. Try not to go through the roof when she finally lets go!
I like the back seat idea - give you the opportunity to really give her a yank.
As a side note, you might have to wack it down to break things loose before you yank on it.
There's a specific tool for removing the headrests. If you try to rip them out and succeed, they will never mount securely again.
Really? Odd that I have popped them out of Classics for years that way and never had an issue. Do you have a link or photo to share of this miracle tool? :)
So that would be a "no" for information on this tool?
On my LWB I can guarantee I was the first to remove them. It had been in the family from new and only had 26K miles on it when I installed the sheep skins for a trip to Arizona. The head rests popped right as described above. I am not saying there is no special tool. It jsut seems odd that no body I have talked to since you posted has ever heard of one nor in 20 years of working on Range Rovers have I ever had an issue with removing head rests.
so good to hear from you again Paul. Your experience and vast knowledge will be a boon to this board.
thanks geneo
Discussion Starter · #12 ·
OK Paul, what kind of tool and where do you use it? Any workarounds? in lieu of the "right" tool?
I spent quite a bit of time searching for this tool. THis past weekend a couple of old timer service techs were in our breakfast group and they confirmed that no tool is needed. They had never heard of a tool either. Although this thread did peak our curiosity. If anyone does run across documentation on a special tool let us know!
I promptly forgot about this until it popped back up. There are some pics in post #10 in the following thread. THey show the indentations on the head rest posts and the spring clips they slide through. Again, nothing locks.
http://www.lrrforums.com/showthread.php?18912-HELP-trick-to-remove-headrest
Discussion Starter · #14 ·
I wound up adding some penetrating oil by dribbling it down the shafts of both seat headrests. I laid the drivers seat back and pushed pulled yanked cussed and wammo-out came the headrest. Tried passenger side and she has not come yet. I will try again. I followed the thread posted in the previous post and just hope I don't wind up pulling the locking mechanisms out on the passenger side.
Tempted to dress up the detents on the posts a bit hoping to make them easier to adjust in the future.
Give the head rest a knock downward. I;ve had a couple that were stubbourn and a quick hit can break the spring clips free.
Were you able to find a replacement Escusion tabs? Mine are broken and the headrest wont stand firm in the forward position.
1 - 16 of 16 Posts
