1 - 14 of 14 Posts
Since ive had my P38 the alarm has never gone off I cant set it off via the ultrasonic sensor because it is broken (new one arriving this week hopefully) is there any way I can manually set off the alarm to test if everything is still operational.
My question is, can I shut the alarm off forever. The dealer has a key which can be purchased without the remote. I think that when you disable the alarm you loose the remote funtion as well. Can anyone offer insite for me PLEASE.
Scotty
Scotty
Yes, select Australian or Gulf market in BECM programming with a Testbook
Thank you
Scotty
996TURBO said:
Scotty
I tried the window test and nothing happened!!? is it because my BeCM is programmed for the car not to panic?
996: what/where should be the Gulf Market?
Gulf market setting is in the BECM configuration via the Testbook or another Programming Hardware like Faultmate.
In France, it's a well known modification to avoid drain battery issues and security desynchronisation (alarm and immobilizer)
without replacing the Remote Receiver.
I think so
Rick-the-Pick said:
You can turn the alarm off without changing the country.
You can still use the keyfobs purely for the central locking without the alarm.
Hi Rick, in which section of testbook do you go? Security?
1 - 14 of 14 Posts
