Status
Not open for further replies.
21 - 40 of 42 Posts
IMPORTANT NOTE
I've now looked at two heater cores (one being my own) where the plastic case is cracked near the screw. I'll annotate the pic below later but you can make out the vertical crack on the side wall of the hole:
I wonder if this caused by over-tightening the screw. It is important that you do not overtighten the screw.
That is a disadvantage of the hex capscrew, it is easy to overtorque the screw and crack the plastic. If the O-ring hasn't sealed, it may be due to other causes. (I'll add some more pics later).
RE. potentially cracked plastic housing... :doh: :doh: :doh:
Thanks Ron for timely warning
Luckily backed it off prior to starting engine...can't tell if any damage done as yet...was thinking I'll "gently" retighten then start engine -see if it leaks, and if so, gradually tighten until no further coolant evident ?
when I removed the original o-rings they were very clean, as was the join...even the pipe ends were clean!
o-rings were just hard and compressed.
:?: Is it worth using some sort of gasket sealer
:?: RAVE recommends lubricating o-rings with coolant...was thinking some sort of waterproof grease (e.g. Hydroseal) as used in tap o-rings...
Thoughts anyone?
ps: Ron, was wondering if you had considered exploring the so-called "electron weld" path to mend the cracked plastic ...
Here is a word of warning...... got a bit carried away when cutting the the duct... following photo is the result.:naughty:
All went very well apart from this. I even had the O rings in stock, part of a large kit I bought of the Bay to do the air con on my old discovery. Think I paid about £4 for the lot (400 odd). Replaced the screw with a socket head cap screw M5 x 25
I just noticed another sign of an earlier O-ring job. The attached photo shows holes to the right of the radio. Which hole would access the screw, the hole in the duct under the glove box or the hole just to the right of the radio. I can't quite tell which way the head of the screw is facing.
Discussion Starter #25
Hi Tim,
I think that duct is the same no matter whether it is RHD or LHD. IIRC, the lower spec models ("SE"?) don't have the rear passenger face vents, so this duct isn't there on them.
If you refer to the original post in this thread and scroll down to bullet-point 12, you can see several pictures of how the duct 'wraps around' the side of the HEVAC box and the location of the screw securing the o-rings. In your 'modified' dash(!!) :) the screw to access the o-rings, would be the one next to the radio, going forwards towards the engine.
P.S. those holes going through the side of the black duct should NOT be there. You will almost certainly be loosing airflow to the rear of the car! I would suggest wrapping the duct in tape at this point or at the very least covering up these holes with some high strength tape! :)
paul.adshead said:
Hi Tim,
Paul, thank you for the clarification. I will tape up the holes in the duct, but first what screw(s) would be accessed through them? If I place a philips in the hole closest to the camera, I definitely feel a philips head and can turn it. The holes goes through both sides of the duct. It was not tightened down all of the way so I gave it a 3/4 turn in to tighten it.
Tim
Discussion Starter #27
These holes probably go to a securing screw on the heater matrix and one of the blend-motors:
[attachment=0:28ts7ehj]paul.adshead.heater.matrix.mounting.jpg[/attachment:28ts7ehj]
Discussion Starter #28
I haven't done the following (- mine is a RHD), but I would imagine that removing the passenger airbag would improve your perspective of what is in there and how to get to things. IIRC the airbag is held on with 3-4 "E10"(??) TORX bolts. I suggest you get the correct size 'TORX socket' on your wrench and remove the airbag.
Dear All,
+1 joined the club although it took me a bit more than 3 hours - I removed the pipes completely to give them a good clean up and also had a delay caused when I discovered that the "O" rings I'd been sold by the RR supplier were the wrong size so had to find a new set from a car parts shop short notice! so in all about 5 hrs start to finish. My observations;
-The duct that goes to the right hand door side vent can be flexed and "kinked" out of the way to allow more room to get at the top end of the removed ducting. I held it in place with duct tape :).
-I cut my duct to remove it. I could not work out how to kink it in situ as one person has said.
-before removing the aluminium tubes I marked mine "top & right" and "bottom and left" to remind of the heater and under bonnet positions.
-My pipe retaining clamp screw was threaded in the plastic portion as well as in the plate. SO it screwed in and out on its own, made getting the plate back on tight very difficult. I spun it a few times to de-thread the screw in the plastic fitting which made getting the plate back on much easier.
-I used sealant around the "O" rinsg as well to make sure.
Otherwise pretty uneventfull and an amazing demonstration of how usefull the forum is. ABS brake block re-furb is next.
Regards
Paul Cundy
Oh and another thing I did after reading about it was to duct tape over all the joints in the heater ducting; at the top "T" join and at the join at the bottom of the radio panekl. The difference its made to the amount of air coming out of the dash vents is noticeable. there must be massive internal leakage at these joins.
Regards
Paul C
Well, I did the job in two parts without removing the vent duct (LHD). The first hour I took everything apart and worked out a way to get at the screw. :x Then I went inside to get over my anger with a glass of wine (well okay, 3). Had a nice diner made by my 13 year old daughter! YUMM! Back out the next morning with new positive attitude and it went very quick. Drained coolant, backed out screw, cleaned pipes, soaked new rings in coolant, put rings on hoses, tightened screw back down, checked pipes for play, filled with water and coolant / water came pouring out the passenger side door and drain!!! WHAT A MESS! Cleaned it up as best I could to protect computer as much as possible. Backed out screw again, checked rings, retightened the screw, added (less) water and no leak! Not sure what happened the first time so be very careful that the screw is threaded correctly and add water slowly with someone watching for first sign of a leak.
The best tip in the process is to use water for testing. I would have had a nightmare if I had put coolant back in to test.
Now any suggestions as to the best way to clean up coolant laced water soaked carpet? :oops:
Tim
Discussion Starter #32
Old towels under the carpet. Change every couple of days for a week or two. Try and leave it parked in the sun with the windows open an inch or so. Either throw the towels away afterwards, or wash them away from other garments - you don't want that stuff on your skin/clothes (- if it gets in your blood it destroys your liver)...
I've been there a couple of times with previous cars when the matrix blew... :-(
Though I did not have to remove the HVAC duct, I did notice that it was not even close to being connected to the duct that feeds the right vents. My truck is left hand drive and the ducts under the right side are a bitch even with the glove box removed. I don't see how in gods green earth a person can get them joined up and taped together. I can't get them anywhere near touching let alone properly joined. They are about 6 inches apart. Anyone else have this problem with a left hand drive?
TIA
Tim
Discussion Starter #34
The "T" pipe (that causes all of the issues) is about 6" wide at the top. Are you sure it is present in your vehicle? Do you have rear-passenger face vents on your car? If you shine a torch into the far right hand side 'dash vent' (just right of the SRS on a LHD), do you see wires and 'behind dash bits' or the inside of the pipe?
See the 3rd and 11th pic , from my original post in this thread, to see pics 'in-situ' and removed, of what the pipe looks like, that connects to the right hand side of the HEVAC box.
Hi Guys, did mine this using the guide, no problems i think someone has been at it somethink before in that area as the air vent was not screwed back in, and a little bit of advice, i found it alot easier to just cut the pastic cover that covers the air vent screws as you get more access later too, it can be put back on with other screw holes and then it covered any way. The only problem i had was the need to drill out the o ring screw and it was so tight, then had to get some heat (gas cooker) on the retainer, afterv taking all the pipes out. If any body does this follow the guide and make your own short cuts as needed, also remember you could well be back in this areas again so make it easy on your self. The biggest thing is that a steeler would have charged £600+ for this job, ps i got the o rings from motor factors cost 50p each.
cheers
Onetime.
I have done this on a LHD RR and the afore mentioned description is the best i've seen, pictures and all. The only diference in a LHD is the removal of the glovebox, passenger side airbag and one cut to the lower frame just in front of the heater core. This cut makes it possible to remove the heater core and replace the new one with no damage to the fins. It also allows greater acces to remove the duct without cutting it. I am doing one of these tommorrow and will include pictures.
Good luck in al your projects!
Shaun
Legacy Vendor
I can now count myself a member of this esteemed collective too :) and had the distinct pleasure :shock: of doing it the hard way.
I've had a slight leak in the o-rings since I got the car last year, but not enough to worry about in a hurry. Then I recently rebuilt the top end of the engine and replaced all the hoses. That's when the o-ring leak became real nasty. Fair enough I thought, what's another day off the road? wishful thinking...
Followed the guide on this site... excellent, thanks fellas... then couldn't remove the screw/bolt in the clamp, probably due to a previous replacement attempt and likely use of loctite to hold the screw in...
So I ended up removing the dash fascia completely, again using the guide at this site.
I was then able to get sufficient access to the screw so I could drill it out and remove it. Replaced it with an allen key head M5 bolt. So far so good.
I'm still soaking up all the old coolant from under the carpet, and will be for a while I think.
Many more photos of this sorry story at http://paulp38a.com/gallery/v/99RR/heaterorings/
The moderators of this site are welcome to use any of them for the purpose of updating the guide.
A tip for avoiding excess coolant spillage on the carpet when removing the pipes at the heater core (apologies if this has been mentioned elsewhere):
  • drain the cooling system;
    in the engine bay, disconnect one of the heater hoses from the coolant rail (at the engine side) and blow hard in to the hose;
    this should flush most of the coolant out of the pipes and heater core.
Cheers, Paul.
I wrote the directions for a new guy down and in big letters said DONT REMOVE THE SCREW.
he thanked me cause that was the most important part of the whole repair.
afox04 said:
yes, here's what you do. take a hole saw, and cut the plastic directly next to the radio. if you do this, then you will get access in a straight line if you take a really long screwdriver (see my pictures at http://rangerovers.net/forum/viewtopic.php?f=3&t=35645 ). i borrowed one from napa, the guys there had it. it was great and i did the same thing where I battled for an hour. got the screwdriver, it came out without ANY issues.
I did the same - cut the hole with a largish hole saw. Popped to the shop and bought the longest scredriver I could find. I removed the instrument panel and disconnected the duct. Top and bottom but did not remove it. It was just a case of a little brute force to move it out of the way to get access.
The pipes dropped out nicely. What I didn't realise that they had swopped places with the top becoming the bottom. They seemed to go back in OK and it was only after complete reassembly that I discovered this.
Second time I did not remove the instrument panel. Just disconnected the rear ac duct at the bottom which allowed enough movement to redo things with the pipes in the correct places. The second time took 15 minutes.
It just needed conviction that I could replace the pipes by feel after undoing the screw.
All
As usual thanks to such a great forum and its contributors I was able to get this job done.
My model is a LHD model!
I followed the procedure referenced here which is to basically remove the AC Controller, and go in through the top RHS of this unit. I also removed the glove box to get access to the side of the o-ring joint.
http://www.rangerovers.net/repairdetail ... oring.html
Some tips:
1. Access: The way in through the AC unit was simple for me....if you dont mind taking apart the panels to remove the AC Unit. I figured it was good to learn this anyway.
2. Phillips Head screw driver. I used a 16" long with a 4 inch handle. Was the perfect length
3. Use a bit of WD40 on the screw before hand. It opened easily...I guess I was one of the luck ones.
4. When you open the glove box, you will see the black vent blocking your view of the o-ring joint. In my case it was already cut (someone was in there before me!). However I am confident that as others have said, you can simply move it back and up and the o-ring joint will be revealed...ie possibly no need to cut it. However if you cut it obviously watch for wires; it is easy to duct tape together afterwards
5. Spill containment. I drained the radiator. I did not bother to open the coolant lines on the engine side to further drain it..was afraid of un-doing a perfectly good joint. I set up a good overlap of plastic underneath the o-ring joint and in the RHS footwell. When the joints opened I had about a 1/2 pint of fluid which the plastic easily contained.
6. Leak test: I did not leak test with water....probably should have done so but my joint held
7. Re-filling the radiator. Since this was my first time to do this...I simply closed the radiator drain and refilled coolant system. However I think it was airlocked as engine nearly overheated when I ran it for a few minutes. After cooling down it was fine on re--start. I think it burped it itself!
8. AC Issue: Also I noticed that the AC unit was showing a -40F external temperature and would not run AC. However after a brief panic and checking this forum, I see that this will simply go away after a few minutes of driving. As it did!
9. Repair is hopefully done and I am down using cat-litter to dry up the residual from carpet.
Does anybody know the best way to completely remove the smell from the carpet?
21 - 40 of 42 Posts
Status
