Status
Not open for further replies.
1 - 20 of 42 Posts
SOURCING THE REPLACEMENT O-RINGS
I searched the RR.net main site and found here, that the Landrover part number is STC3262 (and you need two of them). I phoned the local LR dealer, they wanted NZ$9.94+tax each - total NZ$22.37.
I then searched the RR.net forums and found a post from Jos Geuze, where he lists the o-ring size as "22mm inner diameter and 2.5mm thickness". I went to the local auto store (- Repco) and they had loads of different sizes of o-rings. I bought 2 of the size specified by Jos, for $2 each = $$'s saved.
ACCESSING THE O-RINGS
I'd read from the main RR.net site, that accessing the o-rings to replace them, was a bit of a nightmare. Forum posts of 12 hours and $1000 labour to remove/reinstall the dash sounded horrific. I thought there has got to be a better way, (which I subsequently found)! Credit where it's due, to the contributions of others along the way and from the main site.
The entire difficulty in accessing the o-rings, comes from the one HEVAC duct that passes in front of the o-ring connection and feeds air to the rear passengers' RH face vent. If you take this duct out of the mix, then access is pretty good. The unfortunate thing is, that it is really quite difficult to remove this duct (intact) without removing the dash. So what about removing the duct in two pieces....
PROCEDURE TO CHANGE THE O-RINGS (ON A RHD)
1, Remove RH footwell-light panel above brake/accelerator pedals. Secured with 3 plastic screws/connectors. Disconnect footwell light connector.
2, Remove lower fascia-panel under steering wheel. Secured with four large and two small crosshead screws.
3, Remove upper instrument-panel cover above steering wheel. Secured with four small crosshead screws.
4, Remove instrument-cluster. Secured with four crosshead screws. :!: Make sure ignition is fully switched off when disconnecting any wiring connector to the instrument cluster! It must remain switched off, any time either connector is not present! :!: Disconnect airbag and instrument wiring connectors.
5, Remove LH instrument-cluster mount-bracket. Secured with two crosshead screws, going into the rear of the dash.
6, Remove the duct that feeds the far right dash vent. Slide the 'gate' to the right to release from the lower HEVAC duct; push the duct's right hand end forward to disengage; retrieve the duct through the hole in the dash.
(Picture from RR.net)
At this point you should be looking something like this:
Note, that this picture shows the top HEVAC motor also disconnected (- 2 screws and pull out the motor), but this is probably unnecessary.
7, Slide RH front seat, fully rearwards.
8, Remove windows/sunroof switchpack. Secured with two crosshead screws. Screws are accessed from top front edge, of the open cubby-box lid. Disconnect switch pack connector.
9, Remove RH centre-console side-panel. Secured with two crosshead screws. Refer to these two videos of the side view (9.9MB) and rear view (4.1MB) for the 'nack' to release this panel. As long as you have released the rear of the panel upwards and outwards, you can be quite brutal to release the clip at the front.
10, Remove the RH heater floor vents.
Outer vent.
Inner vent.
11, Drill 10mm access hole in side panel. Make sure that you stop as soon as the drill is through the panel (- other components are not far underneath). Don't worry about leaving a visible hole, this hole is covered by the side panel removed in step 9.
12, Remove the ducting retention screws. Using access hole drilled in step 11 and another screw lower down. These screws and duct are numbered "6" in the RAVE picture below.
Side view showing the aluminium heater water pipes and the HEVAC duct causing the access issues.
Rear view showing where the heater water pipes connect to the HEVAC box (- on the far right hand side).
Photo of the o-ring connector.
Photo showing the o-ring screw (at the top).
13, Disconnect the upper and lower ends of the problematic HEVAC duct from where they connect to the HEVAC box and rear ductwork.
NEW SHORTCUT!
14, Cut HEVAC the duct in two and remove. You will need a sharp hacksaw blade and about five minutes of elbow grease. The top portion is retrieved through the dash hole and the lower portion is slid out from below. The location of the cut can be seen from the photo below. When removed, clean up the 'fur' on the two edges, created by the hacksaw blade, using sandpaper or a small knife - don't make the gap any bigger though!
This now gives you un-precedented access to the heater o-rings and the securing screw. Unfortunately I didn't take a picture at this stage, but you can imagine the access, given earlier photos and the RAVE diagrams above.
15, Drain some of the engine coolant. Remove the header tank cap. Place a clean bucket under the radiator in the engine bay. Using a 21mm socket, gently/slowly undo the drain valve in the centre of the base of the radiator. Be looking to take approx 3-5 litres of coolant out. Re-tighten the radiator drain valve!!
16, Remove the screw securing the heater o-rings. This screw often siezes in quite well - a few tips to remove it:
a, firstly, spray WD40/CRC on any exposed threads.
b, before trying to undo it, try to tighten the screw, slightly further - this often un-siezes the bolt, whilst not destroying the faces of the screw head, that are to be used to undo the screw.
As soon as the screw has started to turn be prepared to catch/ mop-up coolant in the footwell. Remove the screw.
OPTIONAL STEP
17, Remove the two aluminium pipes from the firewall. This is optional, as you can clean the ends of the pipes whilst still in-situ, but I chose to remove them from the car to clean them more throughly. To remove the pipes requires you to release the two coolant hoses from the within the engine bay. Make sure you note the orientation of which pipe goes where! It's your choice if you want to do this step or not.
18, Clean the two aluminium pipe connections. I carefully used an 'artificial wire wool' to remove all of the rubbish/ built up crud/ coolant residue. At this point I noticed some small amount of corrosion damage to the sealing surface on the end of the pipes. It was probably part of the reason for the leak originally. :-(
19, Using a small mirror, look under the dash and check the sealing surface on the heater matrix, that the new o-rings will be going back onto. Using a clean cloth thoroughly wipe this surface of any rubbish/ built up crud/ coolant residue. Do NOT leave any bits of cloth/rag behind.
20, O-ring connection re-assembly. If you removed the aluminium pipes, now put them back through the firewall, roughly in position. As the sealing surface of my own aluminium pipes was slightly pitted, I put some 'oil rated', 'form in place gasket' material on the end of the pipes. Then, put the new o-ring on the end of each pipe. Push the aluminum pipes back into place on the HEVAC box. Put the securing screw back in and tighten it up. I used a new screw, as the old screw-head was damaged during removal.
21, Go and have a coffee. If you used any 'form in place' gasket material then you need to leave it all be, without movement, for at least 15 minutes.
TESTING BEFORE FULL REASSEMBLY
22, Put the instrument-cluster loosely in place and (temporarily) re-connect the two multiplugs. :!: Remember ignition must be off any time either connector is not present! :!:
23, Reconnect the two coolant pipes in the engine bay, if you disconnected them earlier.
24, VERY carefully remove the breather line from the top right end of the radiator (- twist the pipe axially to release the seal). Pour the earlier drained coolant back into the header tank. When coolant appears at the breather port, replace the breather hose. Then pour more of the remaining coolant into the header tank, up to the mark on the side.
25, Run the engine at a fast idle, for 5 minutes. Briefly 'blip the throttle' to 3000 RPM, to flush through any air-locks. Pour any remaining coolant into the header tank and top up if necessary. Replace the header tank cap. Continue to run engine for 5-10 mins more and check for leaks.
REASSEMBLY
26, The HEVAC duct cut and removed earlier, is repaired in-situ using high strength duct tape, as per the photos below. There is enough space to get your hands around all of the sides of the duct.
I then went a bit crazy with the tape, and put it over a few of the other joins too. :)
27, Re-trace your steps, to re-assemble the rest of the components removed.
JOB DONE
Not including coffee time and engine warm up, then with a good breakfast, it would take less than two hours to do this again.
Paul: Thanks for the detailed post on this greatly feared task. I don't have a problem yet, but I am certain it is in my future. Do you think there will be significant differences for a left hand drive??
umm I cut mine the same way, it allowed me to move the bottom portion out of the way but I couldn't get it out all together?
Was a moot point in the end the dash came out for a new matrix :(
On a LHD, then removing the glove box may well give you near identical access as to that gained by steps 2-thru-6 inclusive and should allow you to cut the problem duct (- the top end of the duct may have to stay in place, but that is not a problem, you only need the bottom end out). Further, if you removed the passenger airbag, then I'm pretty sure this will give even more improved access - you might even be able to get the duct out in one piece! :)
I started my o-ring replacement tonight and as it has been said before, this isn't for the faint of heart. I am pretty mechanically inclined, but getting that last screw out was a nightmare. I saw a tip saying to cut a hole in the side of the center console and I ended up doing that and getting the screw out just before I stripped it out completely.
I am picking up a new bolt tomorrow and putting it back together. I replaced the sensor while I was in there even though it really isn't that tough to get at in my opinion, maybe an hour of effort. I just hope this was all of the leak and the heater matrix wasn't leaking too.
I have some pictures of the screwdriver setup I used if anyone is interested and the hole I cut in the side of the center console. The best combination of screwdriver I found was a 1/4" driver with a 6" extension, then a universal joint, then another 6" extension with the bit on the end. This seemed to give me enough play to get where I needed to be the best for me.
Brilliant. This is why this is the best forum.
The cutting the duct is great also for the dreaded blend motors. I cut mine when I did the last set. All it needs is a little duct tape and jobs good, saves a lot of fiddling around.
Thanks Paul for taking the time and effort of posting your efforts.
Big Thanks
Just a quick note to say thank's for posting such a detailed step by step guide for this repair. This was one job that I was not looking forward to attempting! However with this guide I completed it in just over 2 1/2 hours. Thank you for taking the time to publish your findings, it is very much appreciated. :D
Regards
Baz
Thanks for the write up - I am literally in the middle of doing this at the moment. I am on step 14 and have hacked (and boy was I brutal) through the duct at the same point as in the pic but am now having problem pulling out the lower portion of the duct. Any pointers on the 'nack' required to get the bugger out.
I get a drip of water whilst fiddling - Is that normal?
Should I just be brutal and get all Wing Chun!!!
:shock:
I didn't hack anything.
Providing you've removed the screws holding the duct in place, the bottom will flex enough to disconnect from the duct under the centre console. It will take a bit of force.
Ron
FOUNDING MEMBER
Ron, I believe you but I don't follow. I have been wrestling with that stupid duct for the past hour or so and I can't figure out a way to get it disconnected let alone removed.
I'll start a new thread from where I'm at right now and I'd appreciate if you guys could chime in. I feel thoroughly stuck right in the middle of this.
See also http://rangerovers.net/forum/viewtopic.php?t=20437
Re the duct, once the screws were removed I pulled the bottom of the duct forward toward the firewall and them sideways off the ducts leading to the rear of the car. It takes a bit of force but it won't break.
You don't remove the duct, just rotate it downwards and out of the way. I don't think one could remove it without cutting it.
FOUNDING MEMBER
Btw, the o-ring (2.5mm width, 22mm ID) costs at McMaster-Carr are as follows:
$7.63 USD, package of 50, Buna-N (part # 9262K255)
$8.76 USD, package of 10, Viton (part # 9263K306)
I think either Buna-N or Viton will work, but maybe somebody with more clue can chime in.
$6.97 USD, package of 100, M5, 20mm socket cap screw (part # 91290A242)
$8.89 USD, package of 100, M5, 15mm socket cap screw (part # 91290A231)
FOUNDING MEMBER
The pictures at the top of this thread show a few through the cavity where the passenger side airbag is found on LHD trucks. It might be worthwhile pointing towards the RAVE section where removal is described. Seems that going through that cavity is the way to go for reattaching the ducting?
Page 254, WSM vol 2 is where the SRS section begins. The precautions for safing the system begin on page 273.
I can't seem to find the instructions for passenger side removal..
FOUNDING MEMBER
Page 297 in vol 2 has passenger side removal instructions.
The bolts have Torx heads and need an E-10 bit. Check the page for complete instructions, including reassembly.
actually they way you guys do isnt that brilliant.
trying pulling out the hvac module and pull off the passenger side console cover that cvovers the scews and get a long philips screwdriver to it.
but pull the lower trim panel underneath the glove box and you can access everything.
takes around an hour to do.
FOUNDING MEMBER
In order to remove the entire dash facia, the WSM prescribes on page 329 of vol 2 (procedure 76.46.23/99) that the steering column must be removed (step 6). This is apparently because the mounting screw of the upper duct at the back of the instrument binnacle is inaccessible from underneath (blocked by a bracket). Only way to get to it is to remove the column.
In the article based on Jos Geuze's information, there's a reference to Land Rover Malaysia having left out that screw. To me it would appear that it is a very sensible thing to do. I'm getting read to just cut through that screw myself. Here's a picture I just took for reference sakes to illustrate the predicament.
You can see the black plastic bracket just above the duct in the center of the picture and coming off the duct which contains the screw. Its head is underneath that bracket towards the firewall. At the same time, you can see the black metal bracket underneath the duct and how it flares out towards the firewall, just to the upper left of the white NAS sticker.
For reference sakes, the procedure to remove the column is described in the WSM on page 129 of vol 2 (procedure 57.40.01) and you can decide if that's something you really want to do.
how to remove on a lHD vehicle
remove the hose clamps on the heater core hoses on the outside of the vehicle. dont press on the hoses to hard or else they will leak, let the coolant drain out and then use a hose to wash the rest out. Use an air hose to blow out the water to reduce water on your head.
remove the screws in the covers.
remove both side covers for the center console by pulling the rear up and out away from the shifter.
Then tap the cover to release the clip.
remove the cover and if it the opposite side is still stuck pull it up to a get access to the four screws on the HVAC module, remove the screws and the module. remove the radio and the screws surrounding it. Remove the three screws to the upper center console switch. you dont need to remove the one on the driver side underneath the steering column trim piece.
pull out the small foot vent on the passenger side, its two screws, wiggle them out and then you have clean access to the orings. feel for the screw and insert a long philps screwdriver into the hvac module area and aim for the screw. back the screw out enough so it doesnt drop down. pull out the hoses and pull off the orings. install the new ones and tighten the screw up. fill the heater core with water again to see if it leaks. if it does then its possible the orings arent completely tightened up or you have a double oring inside the heater core.
If no leaks, blow out the water and reinstall parts except for the passenger side cover. heat the car up and double check to make sure no leaks,
1 - 20 of 42 Posts
Status
