I just picked up my second '95 LWB...my first one was totaled in November. :x Anyhoo, the truck has been converted to OME springs, but they did not address the yellow illuminated dash light. Does anyone know how to turn it off without using electrical tape? ;-)
Thanks in advance for your thoughts!
Just remove the two relays under the passenger seat. One is for the compressor and one is for the light. Also unplugging the EAS controller under the passenger seat will achieve the same thing.
I removed the two relays, and the light remained on. I then removed K158, the Air Suspension Relay and the light went out.
Thanks, again for your help!
My bad, the second relay turns the light off when energized, therefore wouldn't turn it off if removed. Glad you got it sorted.
