Hello everybody,
Can anyone tell me where I can find detailed info about changing the rear diff.?
In RAVE I could only find the procedure for taking the rear axle out....
What I need is some info about how to unbolt the axles from the diff. and the procedure to fix them onto the new diff.
Is this a straight forward procedure or does it require shims or anything?
Any help is welcome,
Alex
Removing Rear Driveshafts and Hubs Etc. is Covered in Section 64-Rear Suspension. Removing the Diff Assy. is covered in Section 51-Rear Axle and Final Drive in Rave.That is assuming all versions of Rave use the same Section Numbers.
