1 - 10 of 10 Posts
hi All,
have an 04 Range that's making the cowl noise at around 45 to 6omph. i've heard of putting silicone where the rubber end meets the windshield. are there other means to adjust the cowl? looking for a permanent fix to this issue.
it seems to be held down by plastic fasteners. but even with these fasteners, the cowls seems to be pretty loose and moves around rather easily. perhaps putting something on top of the cowl so that it is squeezed down by the hood?
thanks!
The solution I found and that works for a year now is to put a self-adhesive insulation rubber strip (the one for doors or windows) between the pollen filter housing and the lower part of the cowl (yellow arrow). This way the hood pushes down the cowl and the noise ceases. I had to remove the filter housing (white arrows point to the screws) to put the strip, but it can be done by simply lifting the cowl. I had to put 2 strips because they weren’t thick enough, I think about 1cm is required.
Very interesting. My car has been making this wind noise which usually happens during the cold months and the dealer could not rectify it. I was wondering if this remedy will work? It sounds like a sharp "whoosh" from the windshield. Are we talking about the same sound?
I had the dealer re-seal the windshield with silicone. It cost $60 and seems to have corrected the problem.
Thanks for the tip. i'll be trying this very soon. :thumb:
Discussion Starter · #6 ·
Mine is more like a gradual whoosh sound that gets louder as i speed up. it would also increase in pitch. at times it would come about and/or go away randomly. Mine occurs throughout the year.
Discussion Starter · #7 ·
my dealer has resealed and "re adjusted" the cowl. but it always comes back eventually.
DocJoseph, for me it was a wooing sound that started at about 110km/h (68mph). The air coming from the front intake was lifting the cowl, but it took me a while to realize what was happening. I never had this noise again at any speed, even over 110mph... But as I know from my previous LR/Discovery3, noise can also come from the windshield's side trims. However, RR's trims seem much more rigid, so I would go for the cowl that looks very flimsy from the start. You can test my trick by simply inserting something between the filter housing and the cowl and drive a while.
hiko, my noise was always there when speeding, also didn't change in pitch, but you can try to insert a piece of cardboard and see what happens.
Thank You guys for the suggestions. I will try to isolate the problem. The funny thing is that it is not always there.
1 - 10 of 10 Posts
