Vented seats, how much is supposed to be moving through those? On max setting I can feel it, but barely (almost nothing on the back side of the seat)... Wondering if something is clogged up or the fan needs replacement. I can hear the fan running but for the amount of noise it makes you'd suspect more flow.
TIA
~Brad
It's not a high volume, I usually can't even feel the air flowing, just the effect of it on temperature. There are filters, fitted to each fan, 2 per seat, and these could be 'clogged'. There was also issues early on with the way that the seat-back unit was mounted that caused problems with both noise and airflow.
