Well I drove her. Engine still showed plenty of pull and felt very tight transmission wise. Everything works from cruise control, power sidemirrors, wipers, special driving modes, heated steering wheel etc. I couldn't find anything that didn't work electrically. Paint is in great condition. Didnt smoke from the engine bay but tail pipes showed a slight white smoke granted it was about 45-50 degrees out. I tried smelling it but the BBQ smokehouse next door had literally just lit a pile of wood so no luck. Has brand new Pirelli Scorpions. The engine bay is CLEAN. I mean the coils look new, doesn't look like its ever been seriously offroaded. There were 2 or 3 rusty looking objects I couldn't identify. No visible drips by the expansion tank or power steering. All lights work everywhere.
The bad:
Has rust spot/paint bubbles in right rear quarter panel.
Pulls to right quite a bit which has me suspicious because I believe this is where its accident occurred. Haven't pulled the carfax but just might tonight so I'll get more details there.
Power steering whines quite audibly ONLY upon right hand turns.
Has coil suspension.(red coils) if it helps narrow down brand.
Has 2 cigarette burns. 1 in passenger front seat and one blemish burn near 4x4 info button on nav screen. Has about 4 or 5 spots where the leather was either poked or slit. The rest of the leather appears great.
Right passenger sun visor doesn't have a retaining clip so it slightly flops.
Rear entertainment plugs are missing the floppy cover flap.
It used to have some type of sound system as I was able to see aftermarket wiring under rear cargo deck around the spare(which is full size) does this mean locking diff was optioned on it?
The hood release latch is broken and needs to be pulled open with pliers. Funny story about the latch, we tried pulling it open and we basically pulled out about one and a half feet of what looked like sprung coil wire. That finally showed some metal wire in it and then we pinched on that with the pliers and it worked just fine.
Needs a new battery. Every time I turned it off we had to use a battery jumper to turn it back on. After a 30 minutes cruise I turned it off and then it turned back on on its own juice. Sat for about 5 min and dead again.
Hood struts need replacing.
Does not currently have any Land Rover key fobs. Just an aftermarket cut key with no alarm buttons. Central locks work and when locked from outside all doors respond.
All in all I liked it a lot. I'm wanting to trade my Infiniti for it which is worth much more so if they can make an offer of handing over the keys plus a nice check then I think I'll do it. They showed a lot of interest in my Infiniti so I'm just waiting now to see what they come up with.
Thoughts?
Rust: if not rusted through you can sand down yourself after applying some naval jelly, cover with wax until you’re ready to get it painted
Pull to the right: likely worn control arm bushing, these always go
Power steering noise: don’t think too hard about it until you get the pull addressed
Coil suspension: GOOD
Missing clips / caps: eBay and Atlantic British!
Any hood or hatch struts: Give MaxPow a chance on Amazon. They sell a pack of both hood and both hatch struts for around $50 combined!
Sound system: good find! Maybe someone already ran you some heavy gauge wire to the cargo compartment! They might have been thinking sound system, I’m thinking second battery!!!
Full size spare: ASSUMING owner did not replace himself, yes, a factory full size spare denotes both locking diff AND full skids underneath. (Confirm on your 4x4 display)
Hood latch: try the easy way first. Buy a new one and try to just snap or epoxy the new plastic paddle on the existing stub. If no stub you may have to replace entire length. Worth a shot!
Needs battery: unfortunately a reality. Series 95 or series 49 are not cheap ($150 for THE cheapest and the rest are $200+). It
is an AGM so that may factor into price as well. You must pop off hood struts to gain extra range of motion to replace battery.
