I took my rover out today in 98F weather, probably wasn't the best idea, but I did. I took along my OBD scanner and it seemed to be ok staying at about 194 to 199F in the morning, it was about 80F outside at the time. After lunch, I took it back to work and it was roughly 93 or 94F outside and the temp was hovering around 199 to 202F and was starting to frighten me a bit. After work, when it was scorching out at 98 to 100F I went home, with the A/C on full blast of course and the temp seemed ok. EXCEPT when I would stop. It go up to about 206F and the gauge was moving near the red zone. Once home I decided to let it sit in the drive way with the a/c on and see how hot it actually gets. The gauge hit the red zone and the light would fluctuate on and off. The OBD scanner was reading the coolant temp as 210F. The front fans would kick on high when the A/C was engaged and would stay on even if the A/C was disengaged until the temp went down to 206F again. I know my gauge is off because, there is a short in the system so, I could cause the needle to move in the red zone and the light to come on by simply turning the headlights or heated seats on.
My question is, what is the normal operating temp range on these vehicles. I have done searches on the forum and it seems like 190F is the norm so I think mine is running a bit hotter than it should. Thanks in advance!
