My 2014 SCRR just started to do this weird thing with the DRL (signature) where the passenger side will not go to full brightness and then shuts off...so when I'm in park, the DRLs are dim (both sides work)...then I put it into drive, the DRL gets brighter on the drivers side, but the passenger side goes out completely (set on auto when headlights are not on)....then when I put on the headlights, the DRLs go back to dim and both sides work again....
Is it a ballast that makes the DRL brighter? I assume since the DRL works and just doesn't work when on full, its a ballast issue? wondering what the right steps are the solve where the problem is!!
Any help is appreciated!
Thx,Will
2019-2021 Range Rover Sport
Sounds like a short in the wiring... Have the codes pulled from the car to see what it says. This will point you in the right direction
