2006-2009 Range Rover P38A
Hello all,
While changing the headlight bulbs (driver side UK) noticed that the jubilee clip holding the hose onto the radiator was showing signs of corrosion. So I'm going to renew the hose, the hose itself isn't the proper type as it's held on with jubilee clips and marked as Fuel?
I assume that this will be a simple off with the old and on with the new, do I need to worry about air locks?
Apart from the above the RR is going well.
Many thanks
Garry
If it aint broke, don't screw with it. THere is nothing wrong with using fuel line for the coolant system. You'd really kick yourself in the fanny if your nipple snapped off and all because of a grubby clip.
mine has the same replacement on it. has been working fine for years now.
Have to agree with the above. I'd only replace it if you could see it leaking as the cooling system on these can give enough grief as it is!
David.
