Hello All,
I had my 08 RRS in the dealership two times for lousy radio reception. I just
received it back today and they put a brand new radio in the truck.
The reception is just as bad as it was before. Any idea?
At Law said:
Hello All,
AM and FM, or just FM? or XM?
SUPER MODERATOR
Loose antenna connection at the fin?
Banned
2013-2015 Range Rover Sport
Have your dealer, replace the am/fm signal amplifier. It is located in the right rear headliner mounted behind the ceiling speakers, that is connected to the glass mounted/glued anntenna on the, right rear fixed glass. On mine they also found the anntenna wire coming from the dash board , under the center console near the fridge was slightly broken, and grounding out against a screw. after all that was found & replaced it's been 10 times better with FM stations. ( took them 14 hours to do it all according to the work order/reciept all under warr)
Thank you all for your replies.
It is the AM / FM Radio Reception which is not coming in. I have not activated
the Sirius yet, however, I am planning on it.
The truck is going back to Landrover.
Banned
I bet you have the same problem i had... screw in the wires from the front to the back... They'll have to take seats, center console, and flooring out of it to repair it. I'll search and see if I have pics of mine completly ripped apart. Only reason why I trusted them to do it, was because they had the northeast regional tech at the dealer ( and I personally know the owner and GM of the dealership) for 2 days and I insisted him and the shop foreman were the only ones to work on my truck or to order me another brand new one.
