I am having some pretty intense squeeking noise coming from the drivetrain. It corresponds directly to engine speed, not wheel speed at all. It does not matter what speed I am going - if I am accelerating it is very loud, if I take my foot off the gas it is not present, and if I am cruising - gas pressed or not - it is quiet. The speed of the squeek corresponds only to how hard I press the gas - accerlerating from 0-45 sounds the same as accelerating from 30-65 if the gas is pressed similarly.
It sounds like a loose fan - it is definately a rotational noise.
It is not the engine - I can move the shifter into nuetral while driving and rev, and there is no squeeking whatsoever. The transmission is not lagging or shifting abnormally. The noise is present in high and low gears. I believe it has to do with the driveshaft propeller. I am going to grease it and see what that does.
Has anyone experienced anything like this before? Any help or suggestions as to what it might be is appreciated!
