I have a 2008 range rover l322 supercharged and my hood is stuck shut. The cable from the inside completely came out and is no longer intact. I cant even pull on that cable using pliers to open the hood. Anybody have and ideas or techniques to get the hood open? I have no access to the cable at all. Thank you!
I have an '03 which may or may not be different, but when mine broke I had to remove the splash shield and then reach up with a long screwdriver to manually release the latch system. It worked for me, so I could then replace the cable which was not a difficult task.
