Hello all, I have just read all 28 pages on the" brake please read this" topic =thread, we have only had our p38 about a month and just the last 2to3 days I have noticed a slight hissing as I apply the brakes ? is this normal ? the brakes work fine now and then it takes the lights a few seconds to go out after start up the abs light always goes out once speed is over 5 mile per hour as stated in the manual ,I am not getting any clicking sound at all as this seems to be the main problem in the "brake topic". any advice or thoughts graciously received thanks ps ours is a late 1996 4.6 hse running on sequential lpg system and one of the most comprehensive service historys I`ve ever seen with thousands spent and 117.000 miles on.
Mine makes that noise as well (goes PSSSS for about 1/4 of a second at the first press of the brake) , I honestly don't think there is anything wrong. It has been doing it since I bought it, which has been almost a year now.
hello lrscott does yours just do it the first time you brake after start up? , as mine does it every time I brake and as I said the brakes work very well
No it does it every time I brake. Ive been in quite a few cars that do it too, so I haven't worried about it on the rover. Its a very subtle sound too...
· Premium Member
waveydavey said:
I think it's the vacumn assist for the pedal
The ABS hydraulic pump replaced 'vacuum assist', when it was invented ~25 years ago.
The ABS/TC pump gives you 200-300 bar in hydraulic assistance.
'Vacuum assist' gives somewhere up to about 0.8 bar (depending on engine operating conditions,) of pneumatic assistance (- agreed, over a larger diaphragm area).
