Hey all,
Quick question: Is it possible to replace just the hill descent switch in the center console shift surround, or do I need to replace the entire unit for some reason? I broke mine off...
If so, any suggestions about where I can get just a replacement switch? Everything I've found so far is the entire shift surround unit.
Thanks for the help!
-MM
Going to guess you have a 03-06, as +07 would be hard to break off, but, no, I don't believe you can get just the switch.
It surround can come apart, and the switch replaced, if you can find a used one that still has a good switch on it.
Ah crap yes I have an '05 Westminster. I thought that was in my profile but I guess not.
Thanks for the info. I'll keep my eyes peeled for a used one...
I have a surround plate with a good HDC switch but a bad Hi Lo Switch mine Low range switch broke. Ill sell it to you im sure you can pop it out and into the one you have now just be careful with the plastic. They are $300 new for the 03-05 and $140 for the 06. PM me
