I read somewhere that at least one other person had this infuriating high pitch / frequency sound coming from their satnav. It's very high, and barely audible, but it's infuriating.
Anyone else got this?
2016-2018 Range Rover Sport
Mine had it for three days and then just disappeared and i have not heard it in about three weeks. Very strange
I'd be curious if it stays on when certain interfaces are turned off, e.g. Mobile Data, WiFi, Bluetooth (but iirc, you can't turn that off, just disconnect devices, so maybe that's a lever worth toggling too).
Various ICs make all sorts of wicked sounds that can grate against those who can hear 'em, but IME it's typically OTA communications radios that can be amplified by the audio system (or not, and still be heard).
I hear it when I turn on the AC with power of 2+, if the AC is 1 I don't hear it
Another post mentioned this is caused by the air ionizer
I have the same high pitch noise and it doesn’t go away when I turn off the air conditioning. The ionizer is turned off as well. Very strange.
