Hi great site lots of things learnt. Have found the hidden menu but my problem is the warning messages are in French, I know test 10 is the language test but how do I change the language to UK ?
Thanks, have just fitted the mark 4 sat nav unit, so may have something to do with it. I will unplug it for a couple of days and play with the settings.
Did you take out the touch screen? the 05 is not the older system from the bmw earlier models. Why did you install mkIV? I thought that was only for those who had 02-04 non touch nav. units. Enlighten me here?
I had the same issue a number of years ago. I'm not sure what fixed it but this thread may help: http://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/44022-dash-language-has-changed-french.html#post366439
Mine did this after fitting the mk4 sat nav,I cant remember exactly what it was but it was something in the settings menu needed turning off/on and it was something random like speed cameras, this turned language back to english. ?? i'll try and find out for sure.
