Hi All,
So my recently acquired 1984 4 door RR is a little odd. It is a grey Texas import (12ml on the clock when registered in 1984) which has an automatic gearbox and AC. The AC is definitely not a slick installation and the gearbox has some odd arrangements as well. This could be after the fact tweaks by the Previous Owner or adjustments made for the US import together with some smog contraptions. It led a fairly good life (although a little sun bleached) with only 41k on the clock and a bunch of history to back it up.
So the auto box is the 3 speed Chrysler Torqueflite 727 mated to what looks like a standard LT230R. I was playing with the hi-low lever and just could not get it out of hi range. Not a big deal for now plenty other areas to work on. Then I was sitting in the car the other day and tried again and it just shifted in low no problem. Heh? Turns out that there must be a crude electric interlock as I found it will only move when the engine is off(?). My starter interlock is working fine on the auto trans, but putting it in neutral with the engine running alone is not enough, you have to switch the engine off.
Is this a normal arrangement?
Next I have the issue that the adjustment if off (maybe I bend it trying earlier) and it does not stay in low as the lever hits the end of it's travel. It is a little hard to get in there, is there an easy way to adjust this lever?
Thanks.
Thanks.
