1 - 10 of 10 Posts
Hi, my 07 rrs hse from one day to another has brake problems, if i press brake it works like around 70 percent of when fully working
But if i press brake a second time really fast after first breaking, then almost no brakes at all (pedal don't sink to floor. doesn't go down too far!), It's very hard
Also almost no brakes on reverse
Brake pads less than a year old
Help appreciated
Thank you
My first guess would be the Master Cylinder.
Also better have a look at the fluid level. You may have sprung a leak in one of the brake lines. I had to replace the rear two of mine last year. Rusted out.
Brake fluid level is full
Later gonna have to put it in off road and look at each brake line for leaks
2006 Range Rover Sport 2016 Mercedes S550 4MATIC
Take some pictures of the brake fluid level for comparison later. If there's a leak, the level will come down sooner or later.
thanks,
Its been with the brake problem for more than a week, and i use the car everyday
I dont think fluid its leaking
No leaking in any of the 4 brake hoses, and fluid level stays the same
Master cylinder might be bad
Any other component apart from master cylinder can make brakes behave like that ?
I think my brake booster has problems, if i start engine for 3 minutes, press brake, turn off engine then pedal goes back up to resting position
Are break boosters known to go bad on these cars ?
Discussion Starter #10 (Edited)
Did my research, and everything point to a bad brake booster
Brakes work almost perfect only once because of vacuum pump, but pump alone can't handle breaking 2 or 3 times really fast
brake pedal really hard if press second/third time really fast after first pressing because no vacuum to make pedal softer
If wait about ten seconds after pressing brake, then pedal feels normal and breaks almost perfect again
I drive a little aggressive, so now keep a little more distance than usual with car in front
My friends always tell me i think im driving a ferrari😋
1 - 10 of 10 Posts
