I have a strange issue with my HEVAC, the book synbol appears after approx 5 minutes of running but only when the Air Con is switched OFF, if I swith the Air Con on the book symbol never appears despite the Air Con not kicking in. If I turn the ignition on but dont start the vehicle with the Air Con switched off, no book appears. I have had it in a local garage who cleared a list of faults but couldnt diagnose the problem, I think that despite me telling them the fault only appears with the air con off, they checked for the fault with the air con on, in the end I gave up and will try somewhere else for diagnosis but thought I would run it past this forum to see if anyone can shed any light on this issue. The Air Con system was regassed 12 months ago as the evaporator had corroded through and had to be replaced.
Any help grately appreciated
· LIFETIME CONTRIBUTOR
What was in the list of faults they cleared?
They didnt say, I doubt they checked to be honest, I suspect they cleared the faults, put the air con to on, no book symbol so left it. I took it back as the symbol appeared shortly after I switched the air con off and they said they would run the diags again, this time they reported no faults and asked me to "see how it goes" Pretty poor for an independant that specialises in Land Rover really
· LEGACY VENDOR
At least they didn't tell you that you need a new becm. Common lie.
