Hello all, have been experiencing slight delay going into reverse a few times in the past two months. The fluid and filter are new and fresh. It seems only to happen when it’s hot out and have been in stop and go traffic. The longest I’ve experienced is about a 2 second delay and if I immediately put it in drive and back in reverse again, it seems to shift fine. No codes thrown. It’s an 05 rrs supercharged with 186k miles on the clock. Any feedback is greatly appreciated. Thanks in advance.
2010-2012 Range Rover Sport
I don't know if you found any answers yet but if the filter is new and you have the correct atf, my first thought would be a failing solenoid in the trans. The whole set isn't that expensive, I'd consider replacing them. From this point, if it still doesn't solve your problem the fix gets a lot more expensive, I'd assume.
