I cant find out how to remove this radio as I cannot get anything to slide in and around.
It may be the kind you pry off the faceplate but I dont want to break it as I will be selling on fleabay soon.
Here is the pic.
Do you see those two slots at the top on each corner? You slide a flat strip of metal about two inches long into them and they should depress the catches to allow you to pull the radio out. Does not always work that well. You may need to give it a good yank.
No I cant see any slots at the corners but I see these slots
They are not at the corner but these are the only slots I see, I didnt want to shove something in there.
Thx
Yes those are them. Take 2 jigsaw blades and insert them into both sides at the same time
they will release the locks and the unit will pull straight out so you can then unplug the wire connectors
Thanks got it!
You can also taking a hanging file folder and remove the metal strip. Cut it in half and you have two "radio tools". These work for many other cars as well.
