You've either lost a clamp or the flex sleeve from the tank to the fillet neck is damaged. It looks like a short radiator hose with a clamp at each end. Last I tracked one down it was about $25 from Atlantic British.
And, it's probably been leaking to a greater or lesser degree since then.The tank was replaced via the recall though, a few years back.
