Drilled rotors are a gimmick for everyday drivers. "Warped" rotors is something of a misnomer. Rotors do not warp. You can have issues with buildup or you can have issues with hot spots and uneven hardening due to panic braking and uneven cooling.
There are piles of existing brake threads. read what folks say about brake dust because that is really the only issue most Sport owners focus on. Genuine parts give sure footed braking with the correct softness of pads to stop such a heavy rig.
Yes you can upgrade to the Brembo brakes but you really need to ask yourself if you need them. No you can not use your HSE calipers or pads. A Brembo upgrade is everything replaced on the front brakes. There is no " Brembo" for rear brakes.
Again, please see existing threads and make your choice based on reviews and pricing.
