Hello I could do with some help from any experts, What it is the abs light on the dash will not go out i have driven it for certain amount of time for it to go out and it wont turn off. The car was connected to a fault code reader and no errors where shown. Everything works on the abs system i.e the pump and acumulator. The mechanic said he thinks there may be no connection from the abs to the becm?? When i took the abs wires out that connect to the ecu there was water inside the connector. I do not know what to do next as taking it to range rover will cost a small fortune.
Has anyone had this problem before??
Thanks look forward to your replys.
I would dry the connectors out, and give them a good clean first.
What fault code reader was it connected to? A generic OBDII fault code reader probably won't connect to the ABS system properly in these vehicles.
What year P38 do you have?
Marty
RIP Our Friend
There's an entire forum below dedicated to diagnostic equipment.
