Help With 93 lwb Brakes ( line routing)
1295 Views 1 Reply 2 Participants Last post by  ccec
I was replacing the rear brake lines and forgot to take note which brake line goes where( forgot about traction control ). On the abs valve block the lines going to the rear are numbered 21 and 22, could anyone with the same model inform me as to which one goes to which side ( RAVE did not have the same routing as mine )?
If someone could scan page 70 - 6 (ABS Section) from the shop manual and post, you could see the hydraulic line layout.
For the electrical, pages 6 & 7 from the ABS Fault Diagnosis section should help you out.
Cheers,
ccec
